Digital through ACC connector
edited November 2018 in SmartSDR for Windows
I am trying to connect a Signalink USB to the 6500 ACC connector. I am only getting noise on transmit. Receive works OK. I have audio to pin 1 and pin 6 to ground. The ACC button has no effect. I also have to unplug the microphone to prevent pickup during transmit.
Welcome!
  • Member ✭✭
    There are extensive discussions of exactly how to do this available throughout this site extending back to the early release of the 6000 series several months ago. I use the SignaLink USB through the ACC connector on a 6700 with excellent results.. I don't have the exact details at hand now. I suggest you search on SignalLink and other key words. You'll find many details quickly.
  • Member ✭✭
    edited December 2014
    Wade, some items I assume from your comment you are getting PTT triggered (i.e. Windows audio output on USB codec max) Are you selecting ACC in the MIC pull down menu? not the +ACC button Do you have a jumper on the Signalink JP3 to increase output level? Some of us must have the COMP buttton on. BTW, turn off the TX Equalizer
  • Member ✭✭
    edited March 2015
    To prevent mic pickup during transmit use use the ACC selection from the drop-down box instead of the ACC button.
  • Member ✭✭
    edited November 2016
    Dave had the solution for me. I was clicking +ACC and didn't realize there was a drop down on the MIC. That solved the problem. Many thanks to all for your suggestions. Wade, K4YSB
