JT65-HF Rig Control setup: Need help selecting FLEX 3000 COM port for PTT
Douglas Benn
I have a Flex-3000 and want to use JT65-HF low power digital RX/TX. I am currently able to receive JT65 messages but when I transmit although I can hear my audio message the TX function on my FLEX does not activate. I assume I do not have the correct com port selected in the JT65 Rig Control. Currently I am using COM1 as the PTT Port. Can someone please help with deciding what COM port I should be using? Thank you. Douglas WI0DUG
I have an easy to follow step by step installation for JT65 & JT9 in PDF format for the previous generation of radios. Such as the F-5K. 3K and1.5K. If you like to receive a copy. Please email me at my QRZ.COM address. I made an attempt to posted here, but I received the following error "Only image files allowed."1
Ernest - send it or the link to me via e-mail. I'll get it posted.0
This is a great conversation that's separate from the main topic, so I created a new question topic to continue the discussion. Please reference the new topic here: Is the community for all FlexRadio products?0
