Wrong frequency
I have a 6500 radio and I noticed the slice frequency is at 14,300,000 and I used the TEST button on the SmartCAT, the returned frequency was 14,278,652. Any takes on this?
Welcome!
  • Administrator, FlexRadio Employee admin
    edited March 2017
    What CAT command did you issue and what was the complete output? Also did you have one or two slices open at the time?
  • Member ✭✭
    edited June 2020
    The CAT command issued is the default that shows up on the test tab of SmartCAT. I first noticed this when I went to log a DX contact on HRD Logbook. I closed all programs related to running the 6500 and restarted, everything was OK after that. I have no clue as to what took place. Thanks Tim for replying.
    edited March 2017
    There are a lot of commands in the test tab that will return frequency. ZZ and Kenwood commands. Which one is it?
  • Member ✭✭
    edited June 2020
    FA
    edited March 2017
    Perfect. I'll do some testing and report back.
    edited March 2017
    I did some testing and I can not reproduce your issue. Version of SmartSDR CAT are you using?
  • Member ✭✭
    edited October 2013
    I noticed this during the contest too but it was not consistant and I chalked it up to the person posting the spot as being a bit off frequency. So when you click that spot you too would be off frequency. I don't know for sure if that is the case but it seems to be. 73 Greg
  • Member ✭✭
    edited June 2020
    SmartCAT Version 1.1.7.0
