Transmit Interlocks
Bob G W1GLV
On the startup screen there is a transmit tab. What do the transmit interlocks do and what are they used for.
WIOth some exteral configuration you could prevent ransmission if your switch matrix did not have valid transmit anteanna connected, It could be used for preventing transmission when using exteranl T-R relays to prevent hot switching in line preamps/PA's.... Most likel;y on VHF/UHF converter systems. Other uses possible. AL, K0VM1
Thanks Al0
"RCA TX REQuest" - I can not seem to find any functionality for this connector. It has 3.281 VDC in any state (Disabled/Active High/Active) in RECEIVE or TRANSMIT. "Ground" this pin in any state does not inhibit transmit when transmitting in CW. The HW docs say "..grounding the center pin will prevent transmit from engaging" which is what the ACOM2000A will do provide but does inhibit appear to be working. The SW docs only show what states are available but no "signal" info. Perhaps, I am not understanding how this works or on the "wrong RCA jack.. " ?0
Patiently waiting to see when then this comes to fruition, along with holding off RF output until the TX ports finish their timing. Not so good for fast QSK, but good engineering nonetheless...0
The "interlock" TX Request input is NOT currently functional... is this correct?0
Yes, that is correct.0
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9.1K Radios and Accessories
- 14 Aurora
- 151 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 938 Third-Party Software
