Yellow frequency marker follow VFO when switching remotely?
k0eoo
k0eoo Member ✭✭✭
edited April 2019 in SmartSDR for Windows
When I select a slice in the panadapter window the frequency marker turns YELLOW and RED when its not selected.... But when I try and do that with the FlexControl via DDUtil the YELLOW marker doesn't follow the selected slice, making it hard to know what slice your on. This will be even harder with 4/8 slices up on the screen. So would it be possible add this request to your list of features? Thanks, Dennis, k0eoo
  • Tim - W4TME
    edited March 2017
    This is a DDUtil issue. The yellow VFO line designates the slice is "active" aun under the control of the mouse scroll wheel and the SmartSDR FlexControl.
  • Greg
    Greg Member ✭✭
    edited October 2013
    I don't think it is just a DDUtil issue. Logging programs such as N1MM show the same effect. Switching from A to B or B to A does not change bring the focus of the mouse or Flex Control with it. You have to then click on the vertical line for the slice to manually tune. Very cumbersome and causes issues. If I change to VFO B and then use the flex control to tune I end up changing VFO A instead because that's where the flex control focus stayed. 73 Greg
  • Steve - K5FR
    Steve - K5FR Member ✭✭
    edited April 2019
    This is indeed a DDUtil function, but the FlexLib API has no functionality to do this. I've asked for it, but was rejected I think.
  • Greg
    Greg Member ✭✭
    edited October 2013
    It happens with logging programs connected directly to the SmartCAT port bypassing DDUtil. At least it did for me using N1MM.
  • k0eoo
    k0eoo Member ✭✭✭
    edited December 2016
    Hi Tim, some how my IDEA got changed to a problem, I don't understand how that happened... So are you saying this is not an idea Flex is interested in adding at some time?
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2017
    In light of the above comments is this still only a DDUtil issue? Soon I expect Flex will offer additional Flex control knob functions but isn't this still an issue with Logging Programs such as N1MM and DX4WIN, not to mention all the others....
  • Tim - W4TME
    The radio is doing exactly what it is instructed to do by a third-party client (CAT / DDUtil). This is not a change that needs to be made in SmartSDR, but a change in how the third-party client interacts with the radio.
  • Tim - W4TME
    Technically, yes.
  • k0eoo
    k0eoo Member ✭✭✭
    Steve, K5FR, said: "This is indeed a DDUtil function, but the FlexLib API has no functionality to do this. I've asked for it, but was rejected I think." So Steve is incorrect, and there is a way to do this without changes to the FlexLib API??
  • Tim - W4TME
    K5FR is correct in that it is a DDUtil function. And for any third-party application to tell the radio to do something is a FlexLib API function. Regarding the feature request, I do not see a request in the developer's database requesting this feature for FlexLib.
  • k0eoo
    k0eoo Member ✭✭✭
    Hi Steve, Tim says they don't have your request, maybe you can resubmit?
