Digital Mode PSK-31 has Multiple Identical Streams in DM780 SuperSweeper
Jim Bryce W5HFS
Running 1.0 with Win 8 and DM780 using SuperSweeper in PSK-31. I observe multiple ribbons (limited to two, so far as I can tell for now) of the same communication offset by several hundred hertz. The distance in hertz between the identical ribbons is different for different signals. I've not seen this before. The two streams are not together in time; that is one lags the other. Conditions are quite good on all the HF bands. I'm making this observation on 14.070 today, 14 October 2013, aprox 1600z and later when I started operating. It is just possible there is nothing amiss in the equipment and software and the cause is long-way/multi-path/LDE slightly shifted in frequency by doppler or ?? I await responses. --Jim, W5HFS
Jim: I have observed the same multiple ribbons on the PSK-31 mode using DM 870. This has appeared since using the latest version of HRD. I turned DM 870 off and started FlDigi. The multiple ribbons did not appear. I have observed multiple carriers spiking across the waterfall when a strong digital signal is received. These issues appear to be present in the new versions of HRD. I will keep tracking your community tag to see if anyone using HRD are having similar issues. Bill W4EY0
Thanks. Please note that I am not using HRD, only DM780. --Jim, W5HFS0
I do not see this reported behavior with other digital mode programs.0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
