Need to purchase a new pc. Any suggestions from the 6500 owners? Desire plenty of headroom for the
Howard K2AQ
While SSDR works on a netbook with limited horsepower, I am most pleased with a quad core 3 GHz machine with an Nvidia GeForce GTX 660. For the full 30 FPS panadapter function, you do need a good video card. Get the best you can. The video card is the key to running SSDR, I think. Signal processing happens in the radio, so it really is all about the display/interface. Good luck & ENJOY!!0
An Intel i3,i5 or i7 will have all the PC processing power you need, but just make sure you do not get a machine that shares the CPU processing for graphics, basically stay away from embedded graphics. Get a machine (or build one) with a dedicated GPU (Nvidia or ATI). Set your budget, and take your pick. http://www.videocardbenchmark.net/ One of the best value cards at the moment is the ATI Radeon HD 7790 with a Passmark of 3000+ for just around $100 For $200 ish you can get a Passmark of 4600 with the Radeon HD 7950. Aim to spend no less than $100 and you will have a more than adequate GPU.0
George is right, Flex came out a while back and said you need a video card with a passmark rating of 400 or higher. Tim did a write up on this very topic and it should be posted if you search on topics.0
I'm using the GTX660 with a passmark of 4,115 (more than adequate) but one of my main considerations was support for up to 4 monitors. I have 3 monitors set up currently and it performs very well. Here is a good web site for video card comparisons you might find useful. http://www.videocardbenchmark.net/gpu.php?gpu=GeForce+GTX+660 Regards, Al / NN4ZZ CLICK to enlarge.....1
Thanks all.0
The best thing I ever did...was let Neal Neal Campbell build my machine. Fantastic support, and fantastic computer. my suggestion....get as many big SSD drives as he can fit into it.1
- 319 Community Topics
- 576 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
