SmartSDR&Flexcontrol knob
Slawomir
Is it possible to retune frequencies in the Flex 6700 Flex control knob with DDUTIL? I failed to realize. Slawomir
Sure: 1. Start SSDR 2. Disable FlexControl in SSDR 3. Start DDutil 4. Programming DDUtil v3 with port allocated with FlexControl (see you Device Manager in Win) 5. Activate check box FlexControl in DDUtil -> completed at next start you skip 2&4&50
Sergey, how do I disable the Flex control in the SSDR if I do not have control Flex? Maybe you have a different version of the software? Slawomir0
There is a settings menu in the top left corner, then choose Radio setup and then the General tab. Settings > Radio Setup > General0
Hi Robert, Thanks to your help. Tunable FVO is already running. Did it work when you configure the AUX function? Slawomir0
Slawomir, i am not sure, but what does it mean AUX function in you case ?0
I can get DDUTIL running fine with the radio, the problem I have is that when the slice receiver reaches the edge of the panadapter, the panadapter doesn't scroll, the slice receiver just disappears right off the screen.0
Hi Michael, i will check it today later on, not sure but or in direct Flexcontrol connenction to the SSDR or with tuning with mouse weel, Panadapter scrolling. Unfortunately this is not working with CAT commands (ex. with DX cluster)0
Agreed, I have the same problem with changing frequency via CAT.0
Hi Sergey, I think the other functions assigned to AUX1, AUX2 and AUX3.0
Clear Slawomir, this buttons not yet fully supported in DDUtil but partly, pls read completely page http://k5fr.com/DDUtilV3wiki/index.php?title=TKnob Michael, with mouse wheel tuning Panadapter scrolling follow with slice RX, but not with F.C. and CAT commands1
Sergey Thank you for your help. Slowly recognize opportunities DDutil + Flexcontrol. 73's0
- 338 Community Topics
- 580 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 892 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
