Can I please get the levels and detailed functions for the FlexWire connector on the back of a 1500.
Jerry Kenyon
The audio in/out on the FlexWire connector is line level, 1 volt peak to peak .0
Thank you for the info on the levels. Can you tell me more about the control of them? Are they constant? Can they be adjusted? Where in the audio chain are the pick off points? I'm trying to decide if I can use them to interface with an Icom radio. I would like to use the Icom as the transmitter, and the Flex as the receiver. Ptt isn't a problem. Nor is the antenna switching. I'm thinking of using the mic on the Flex, and passing the audio and switching to the Icom from the FlexWire port. Thank you. Jerry de kb7lnr0
They are controled in via the PowerSDR Mixer0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
