fldigi Question
DonS
Member ✭✭✭
Does fldigi support more than one panadaptor with a single slice on each?
Sort of. You can run multiple instances of Fldigi on the same PC, each having one unique audio input and output. I do this with a FLEX-1500 and a FLEX-5000+RX2 where the 1500 runs on instance of Fldigi and the FLEX-5000+RX2 runs two separate instances (one for RX1/TX and another for RX2). PowerSDR uses VAC to create seperate virtual sound cards for each version of Fldigi. Currently you can set up SmartSDR for Windows to route audio from each slice to the left and right audio channel. So using two separate sound cards, you can run two separate instances of Fldigi each configured for a separate sound card. Refer to the Fldigi documentation for configuring multiple instances of Fldigi on the same PC0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
