Transmitter control panel truncated with vertical resolution of 768
Tom Hoflich
With v1.0.0, the transmitter control panel is cut off about a third of the way into the equalizer. The vertical resolution of this computer is 768. This was ok on the previous releases. Anything that I can do?
3
Increase the vertical resolution if your monitor supports it. SmartSDR is greater than 768 pixels (I think it is ~ 920)0
Tom, ALternately, you can grab ( left click hold ) the top edge of the VOX control panel and slide it down and the EQ panel should pop up AL, K0VM0
- 319 Community Topics
- 576 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
