Transmitter control panel truncated with vertical resolution of 768
Tom Hoflich
With v1.0.0, the transmitter control panel is cut off about a third of the way into the equalizer. The vertical resolution of this computer is 768. This was ok on the previous releases. Anything that I can do?
3
Increase the vertical resolution if your monitor supports it. SmartSDR is greater than 768 pixels (I think it is ~ 920)0
Tom, ALternately, you can grab ( left click hold ) the top edge of the VOX control panel and slide it down and the EQ panel should pop up AL, K0VM0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
