Cannot TX on ANT2.
k0eoo
Member ✭✭✭
I don't think this has been reported yet and nothing in the release notes. I have a 6500/V1.0.0. I am not able to transmit on ANT2. I can only receive on ANT2. Also, the RX slice panel only displays ANT1 with ANT2 is selected.
We have determined that this defect needs immediate attention and we have entered it into our bug tracker for resolution.0
We just completed comprehensive testing on the FLEX-6500 with SmartSDR v1.0.0 and cannot reproduce this behavior. Please power down the FLEX-6500, remove DC power from the radio for a few minutes and then power everything back up and let me know if you still are experiencing the inability to transmit on ANT-2.0
Hummmm, I'll check when I get home and let you know...0
Found the problem. I didn't know how to set the TX antenna. Figured it out and ANT2 works fine. I was setting the antenna in the pop-out display on the left thinking it was setting both TX-RX antennas and it wasn't. VERY sorry I gave you a start! This is what you don't need right now....0
No problem!0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 37 Aurora
- 947 Maestro
- 924 Genius Products
