Pulsating Noise While Transmitting
Are you directly connecting the mic to the radio or do you have any audio processing gear in between?0
There is an Aphex Exciter in the balanced line. Switching it out of the line did not help.0
So am I correct in assuming that this happens every time you start the radio or does it happen every time toy run SmartSDR?0
So far, this is the first time (that I am aware of)... wondering if there is something I have overlooked.0
It may be just an issue where the radio needed a "state" change to clear it up. If you can reproduce it, I would love to know the steps to do so0
I will watch closely for it to happen again; if/when it does, I will report back.0
Thanks!0
any idea of what is causing this, i have been away from the radio for 2 months and just started using mine again and now 2 days in. a row this has started and i have to restart the radio to clear it up. it was never an issue before
another thing i notice is since getting back online i'm having dhcp issues (which i recognize that issue) the radio shows no pans on the 6600M screen, is there any chance that somehow a dhcp issue would allow pans to still work but transmit to pulse? i don't see how, if the ip changes the front panel of the radio show loses access to everything, i only mention it because i know i have some weird new network issue i have to work out. Could that network issue cause this?
Im trying to transmit from the microphone directly connected to the radio, however if i switch to any other input, i don't hear the pulsing like i do on the mic input, i do however here a very quite ticking sound from the speaker when i press mox, so i think its happening in all transmit modes. I should test tuning next time i see it happen.
So i discovered that the mic would also just quit working, i would change profiles between default, FHM3 and FHM3FD sometimes it would start working sometimes not, until that would not even work, i cleared data and now its working, you really need to resolve the persistent data issue
- 633 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
