Master Volume Control Delay ?
Richard G7EIX
Ok, I just did a complete power cycle of the radio and restarted the PC - the delay is in no way as bad as it was (2-3 seconds to adjust) but there is a delay when adjusting still (around 200ms would be a rough guess).0
And this PC is connected to a GB switch - the same switch as the radio.0
I also had a delay yesterday on initial setup. On power up today, also see that there still is a small delay on volume control, though not as bad as initially.0
It seemed as though the delay on my 6500 was worse when I had the Display FPS turned up higher. I usually run about 8-11 FPS. I need to test this again when I return to the shack. BTW, the delay was on BOTH the master volume and headphone controls. I totally powered it down last night, and will test it from a cold start again this evening.0
I just tried with the headphones and the same delay is apparent. Nothing that I cannot live with but a definite delay when adjusting up and down. More easily noticeable if you rapidly move the slider back an forth several times rapidly. It's also the same with FPS down to a low level too.0
Thanks for reporting this. We have added this to our Bug Tracker for further examination.1
This defect will be fixed in SmartSDR v1.10
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
