panadapter baseline off screen
Dale G. Brown
I can not get the base line of the display to be on the panadapter. I use the up arrow and down arrow on the right side of the display. at one end of the arrow, the peaks are off the screen. at the other end, the base line is 2 inches wide.
Did you try sliding the bar rather than using the arrows?2
Dale. the up and down arrows are for zooming the axis in and out. You need to click and drag the axis scale to move the baseline.1
Thanks for the tip. I did not see this function in the notes.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
