How about adding a SmartSDR feature to automatically save all settings on exit? What about a 'standb
Arnie
It sure would be nice if I had the option to have SmartSDR automatically save all settings upon exit? It is really annoying to have to adjust volume sliders, freq, mode etc every time I run SmartSDR. It would also be nice to have the ability to 'standby' the radio without having to exit SmartSDR. Anyone else think these would be useful basic features that SmartSDR should have had? 73 de Arnie W8DU
That is what all the discussions abort "persistence" are about. Some has been added in the latest release. More is coming. Hang tight.0
Ken, Did any persistence make it into v0.16.4? This definitely needs to be there before it is released to the general public. I don't like the fact that it does not remember my power out setting. I use an amp and only drive it with 30-40 watts. When I come out and back in, it is normally back up to 100 Watts. I sure don't want to **** my amp. 73 de wi4usa Thom0
Thom, you are right regarding amp, ALC, in this case also most wanted feature to prevent such claims, but in Ver 1.0 (roadmap). I believe what FRS hear us0
We are continuing to add more and more items to persistence. Here's the current list, but it is growing every day. We will add persistence by band after V1.0 -- this needs some design work around how it should operate. For example, the thinking is that we would use an 80m frequency that we saved if you typed "3.75" into the frequency display, but we would if you hit the "80m" band button. We need to discuss if band-stacking makes sense in this radio, etc. If you guys are interested, we can post the design before we implement this part and get feedback. Anyway, here's the list as of YESTERDAY: TX_MIC_INPUT TX_MIC_LEVEL TX_MIC_BOOST TX_MIC_BIAS TX_MIC_ACC TX_MIC_COMP_ENABLED TX_MIC_COMP_LEVEL TX_VOX_LEVEL TX_VOX_HANGMS TX_CW_BREAKIN_ENABLED TX_CW_BREAKIN_DELAY TX_CW_IAMBIC TX_CW_IAMBIC_MODE TX_CW_SWAP TX_CW_PITCH TX_CW_SPEED RX_EQ TX_EQ RX_EQ_ENABLE TX_EQ_ENABLE TX_FILTER_LOW TX_FILTER_HIGH TX_MET_IN_RX TX_AM_CARRIER TX1_DELAY TX2_DELAY TX3_DELAY TX_DELAY ACCTX_DELAY PTT_TIMEOUT TXREQ_ENABLED TXREQ_POLARITY ACCTXREQ_ENABLED ACCTXREQ_POLARITY RADIO_LINEOUT_GAIN RADIO_LINEOUT_MUTE RADIO_HEADPHONE_GAIN RADIO_HEADPHONE_MUTE1
Since I began this topic, I feel I need to respond: These are good starts. I do think 'last frequency used' on each band would be a great addition as well as or probably part of band stacking registers with last 5 frequencies per band. Also, I would like to see a 'standby' or 'offline' mode implemented. Tnx for your response and cooperation... 73 de Arnie W8DU p.s. Really, beside persistence, virtual audio cabling is of utmost urgency. This should have been first and foremost. Seems silly in this advanced radio to have to deal with the distortion inherent in unnecessary digital to analog to digital conversions.0
Good list so far. I vote YES for band stacking registers. 3 per band should be adequate, especially if they store Freq. Mode, Filter setting, ANT, Preamp setting and "Audio profile" (separate TX/RX EQ levels, bandwidth & other audio settings for each band and sub-band) Additional persistence I would suggest are: Display FPS (It is a pain in the **** to have to adjust this every time for two different pans) ANT selection (perhaps eve per band) Preamp setting AGC speed (preferably saved separately per mode) AGC-T I don't want much... Just the world! Thanks for all the hard work!0
BTW... I would have any direct frequency entered go to that exact freq. but pressing the band button go through the band stacking registers. If I enter 3.75 then I want 3.750000 If I want it to go to another freq I will enter it precisely. If I want to step through my band stacking registers, I will hit the button. I think that is the way PSDR works and I like it on my 1500. (But I haven't used it much since I got the 6500 so I may not remember.)0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
