CW Delay moved....(0.16.4)
Al_NN4ZZ
Member ✭✭✭
I questioned that move also. I also like to adjust delay depending upon traffic, band conditions, speed I am sending, etc. It would be more convenient to have the delay control on the front panel with the other two. Perhaps they did it this way so they didn't have to reconfigure the front TX panel display, but simply reuse/repurpose the slider for sidetone instead of delay. (perhaps to speed up release of v. 1.0?) I would suggest rearranging the CW panel to include all three functions at some point in the future. But a big thanks for the adjustable sidetone!0
And add that the cw delay defaults to zero when starting SmartSDR - should have been add to the persistence list.1
Don, Agree and to make it worse, you don't see that unless you go to the CW tab. Easy to forget! Regards, Al / NN4ZZ0
This discussion has been closed.
- 654 The Flea Market
- 385 SmartSDR API
- 51 Aurora
- 967 Maestro
- 938 Genius Products
