Alignment of two panadapters on the same frequency
K4EAR
K4EAR Member ✭✭
I set 2 panadapters up on 40M , same freq, antenna,bandwidth, mode, agc-t with each slice on the same frequency. The vertical grids are offset about 1.85kc when you look at the carrier lines, yellow/red on the GUI from the top to bottom. No matter what bandwidth of the slices selected.
  • Stu Phillips - K6TU
    Stu Phillips - K6TU Member ✭✭
    edited May 2020
    Which release? and BTW, I thought you didn't turn your 6700 on? Stu K6TU
  • K4EAR
    K4EAR Member ✭✭
    edited April 2014
    v 0.53.13, say what?¿, .newest version installing now.
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    One thing to remember is not the slice but the panadapter zooming can make a difference in relation to horizontal zooming . Try this, delete all panadapters (the "x" in the upper right of each panadapter) then reopen each panadapter (at the very bottom of the SmartSDR border) They both should be scaled on centered around 14.100 . There should a slice open in Panadapter A, you can then open a slice in Adapter B , scaling in both should be the same. Now with out zooming in on the bottom scale open the band buttons, go to 40 meters, in each panadapter, scaling should be the same. Now click the magnifying glass icon with the + in it, the same for each panadapter.. double check make sure the scaling is the same. Try that.. The variable zoom in the panapter will throw you off.
  • K4EAR
    K4EAR Member ✭✭
    edited April 2014
    I aligned both panadapter slices but still see an offset. The "zooming " is the same for both.i
