Alignment of two panadapters on the same frequency
K4EAR
I set 2 panadapters up on 40M , same freq, antenna,bandwidth, mode, agc-t with each slice on the same frequency. The vertical grids are offset about 1.85kc when you look at the carrier lines, yellow/red on the GUI from the top to bottom. No matter what bandwidth of the slices selected.
Which release? and BTW, I thought you didn't turn your 6700 on? Stu K6TU0
v 0.53.13, say what?¿, .newest version installing now.0
One thing to remember is not the slice but the panadapter zooming can make a difference in relation to horizontal zooming . Try this, delete all panadapters (the "x" in the upper right of each panadapter) then reopen each panadapter (at the very bottom of the SmartSDR border) They both should be scaled on centered around 14.100 . There should a slice open in Panadapter A, you can then open a slice in Adapter B , scaling in both should be the same. Now with out zooming in on the bottom scale open the band buttons, go to 40 meters, in each panadapter, scaling should be the same. Now click the magnifying glass icon with the + in it, the same for each panadapter.. double check make sure the scaling is the same. Try that.. The variable zoom in the panapter will throw you off.0
I aligned both panadapter slices but still see an offset. The "zooming " is the same for both.i0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 123 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 698 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 922 Third-Party Software
