Alignment of two panadapters on the same frequency
K4EAR
I set 2 panadapters up on 40M , same freq, antenna,bandwidth, mode, agc-t with each slice on the same frequency. The vertical grids are offset about 1.85kc when you look at the carrier lines, yellow/red on the GUI from the top to bottom. No matter what bandwidth of the slices selected.
Which release? and BTW, I thought you didn't turn your 6700 on? Stu K6TU0
v 0.53.13, say what?¿, .newest version installing now.0
One thing to remember is not the slice but the panadapter zooming can make a difference in relation to horizontal zooming . Try this, delete all panadapters (the "x" in the upper right of each panadapter) then reopen each panadapter (at the very bottom of the SmartSDR border) They both should be scaled on centered around 14.100 . There should a slice open in Panadapter A, you can then open a slice in Adapter B , scaling in both should be the same. Now with out zooming in on the bottom scale open the band buttons, go to 40 meters, in each panadapter, scaling should be the same. Now click the magnifying glass icon with the + in it, the same for each panadapter.. double check make sure the scaling is the same. Try that.. The variable zoom in the panapter will throw you off.0
I aligned both panadapter slices but still see an offset. The "zooming " is the same for both.i0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 977 Third-Party Software
