Filter Widget missing
Greg
I was tuning around the bottom of 20M below 14.014 MHz. When I went to use the filter widget it would not come up. I would tune lower and it still would not come up. I tuned up above 14.014 and it came up....then I went lower again and it would come up....sometime, sometimes not. There is something going on that is keeping the widget from showing sometimes. 73 Greg AB7R
Also, When I can get it to show at the very bottom of the band it is no longer centered although I did nothing to make any changes and the signal does not sound any different. I am on 14.000.770 and the tuned frequency is now on the left dotted line of the widget and not the center tick mark. Greg0
Greg, I think it has to be when "Surfing" or sliding down, with the slice hard to the left side of the panadapter, the widget does not display.. I guess all the graphics gets tangled up hard to the left. Doesn't seem to happen to the right side.. Thanks for the information .0
I have also noted the problem.. You might be able to access the widget by going down to where it normally is and then sliding "up the band" from its normal location.. Additionally, If RX slice A is near the center and you open RX slice B in same panadapter and place it to the right of A, the widget may be absent from slice B.. It has something to do with the RX control flag being on the right side of the zero line. AL, K0VM0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
