Flex6500 GPSDO and FLDIGI are killer FMT app.
Andrew VK5CV
The title says it all. With the Flex 6500 and FLDIGI frequency analysis mode I can measure frequency to 2 decimal places! Andrew de VK5CV/VK5ZUC.
Can you illustrate this with a screenshot?0
Well Andrew, FLDIGI freq = RF Freq + Audio freq from waterfall0
Although the RF sampling rate is very accurate with the GPSDO, do we know that the effective sampling rate of the 6000's DAX output audio is as accurate?
If everything inside the 6500 or 6700 is clocked from the same master oscillator this is probably true, but I can imagine designs where output audio resampling occurs using another (and less accurate) clock domain.
I ask because I am also interested in FMT without having to use external hardware.
Another issue I just noticed from another thread. Tim reports "The specifications of the FLEX-6000 is to report frequency in 1 Hz increments." What is the actual accuracy of the synthesized frequency? It is unlikely that the frequencies lie right on the integer boundaries.
Hi Bob, in the installation package of the MIxw32 - > http://mixw.net/, exist small apps for checking sample rate of audio device (48kHz supported),
sorry screenshot on rus:
Sergey
I have been running Check SR for a while.
-30ppm and -20ppm input and output so 50ppm all up
On the 10MHz GPSDO output I get 999999.94.
6parts per 10E9 total
GPS SSDR 5 e-11 estimate on the setup screen
thus DAX ( and FLDIGI?) 60pp10E6
Good enough for an ionospheric path.
Andrew
Hi Andrew, you is right, this radio support reception from universe :-)
my GPSDO estimation on setup screen depends on time of the day from e-10 to e-12 :
And FLDIGI lets me add a 60 ppm correction.0
- 115 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
