Atu Byp in cw
Brad - N6SPM
On SSDR 0.15.10 and the new 0.15.13 release, when I tune on SSB, the Success shows and the Atu stays on. When I tune on CW, I get a Success in green, but the Atu grays and the Byp illuminates. Is this normal or am I doing something wrong? BTW, the resulting SWR is always fine. Perhaps this is because my match is so good without the tuner it switches out? Sorry if this is pedestrian, but I'm completely new to Flex and have no history with it whatsoever. It's just that having the Success and Bypass on at the same time (in CW) seems peculiar to me. thx es 73 Brad - N6SPM
This appears to be a software bug where the status indicators are not updating properly. I have entered your problem description into the developer's bug tracker for additional investigation. Thanks for the report Brad.0
Are you saying you get different results on CW and SSB on the same frequency? If so, that sounds like an issue that we will need to look into. It is worth noting that if the match is better when in Bypass mode, the ATU algorithm will leave the radio in that state. The success indicator is the key here. Update: Tim has tested this and verified different results on CW and SSB on the same frequency.0
Thanks Eric. Unless I hear otherwise, I will let Tim's testing provide your baseline for investigation. Let me know if more information about my circumstances are required. Thanks, Brad - N6SPM0
We found and fixed at least one problem that may have been contributing to this issue. This fix will be in the 0.16.x release.0
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 148 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 713 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 935 Third-Party Software
