Still having a problem getting SmartSDR CAT to load.
Richard, Following the same path I started by looking for VPSK in c:windowsinffolder...setup.devlog just to see if the file was there. setupapi.dev.log was not there. I then went to REGEDIT and followed the path you referenced HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServices I did find ftvspenum but not the other two. I deleted ftvspenum, rebooted and run the SmartSDR CAT.exe The problem did not go away. Early on I sort of figured the problem may be in the registry but could not locate anything that pointed to the problem. So I'm still not yet fixed. Also used a global search using ftv* but nothing came up. Here's the setupapi.setup.log [Device Install Log] OS Version = 6.2.9200 Service Pack = 0.0 Suite = 0x0100 ProductType = 1 Architecture = amd64 [BeginLog] [Boot Session: 2013/03/02 11:22:49.498] >>> [Sysprep Specialize - {fe515e03-14f0-de11-b607-001cc0c81e6f}] >>> Section start 2013/03/02 11:24:16.780 set: BIOS Release Date: 06/30/2011 set: BIOS Vendor: Intel Corp. set: BIOS Version: KGIBX10J.86A.5936.2011.0630.2250 set: System Family: set: System Manufacturer: set: System Product Name: set: System SKU: set: System Version: dvi: {DIF_REMOVE} 11:24:16.827 dvi: No class installer for 'Local Print Queue' dvi: No CoInstallers found dvi: Default installer: Enter 11:24:16.827 dvi: {Remove DEVICE} dvi: InstanceID = 'SWDPRINTENUM{AF023001-E0B1-4934-B8E8-D92D736469BE}' dvi: {Remove DEVICE exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_REMOVE - exit(0x00000000)} 11:24:16.843 dvi: {DIF_REMOVE} 11:24:16.843 dvi: No class installer for 'Local Print Queue' dvi: No CoInstallers found dvi: Default installer: Enter 11:24:16.843 dvi: {Remove DEVICE} dvi: InstanceID = 'SWDPRINTENUM{8B164225-43E2-473F-B32C-CD2DA77617C7}' dvi: {Remove DEVICE exit (0x00000000)} dvi: Default installer: Exit dvi: {DIF_REMOVE - exit(0x00000000)} 11:24:16.843 <<< Section end 2013/03/02 11:24:28.293 <<< [Exit status: SUCCESS] >>> [Setup Update Driver Package Signatures] >>> Section start 2013/03/02 11:24:17.560 set: oem0.inf/prnms001.inf -> signed by 'Microsoft Windows' (SignerScore = 0x0D000003). set: No driver package signatures to update. <<< Section end 2013/03/02 11:24:17.623 <<< [Exit status: SUCCESS] >>> [Setup Plug and Play Device Install] >>> Section start 2013/03/02 11:24:17.623 set: ACPIPNP0C021 -> configured [machine.inf:*PNP0C02,NO_DRV_MBRES] (ConfigFlags = 0x00000000). set: ACPIPNP0C022 -> configured [machine.inf:*PNP0C02,NO_DRV_MBRES] (ConfigFlags = 0x00000000). set: ACPIPNP0C023 -> configured [machine.inf:*PNP0C02,NO_DRV_MBRES] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_3B42&SUBSYS_424B8086&REV_053&33FD14CA&0&E0 -> configured and started [machine.inf:PCIVEN_8086&DEV_3B42,PCI_DRV] (ConfigFlags = 0x00000000). set: PCIIDEIDECHANNEL4&2FC6688B&0&0 -> configured and started [mshdc.inf:Internal_IDE_Channel,atapi_Inst] (ConfigFlags = 0x00000000). set: PCIIDEIDECHANNEL4&2FC6688B&0&1 -> configured and started [mshdc.inf:Internal_IDE_Channel,atapi_Inst] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D155&SUBSYS_00000000&REV_113&33FD14CA&0&40 -> configured [machine.inf:PCIVEN_8086&DEV_D155,NO_DRV] (ConfigFlags = 0x00000000). set: PCIVEN_1102&DEV_0005&SUBSYS_00311102&REV_004&2CFE2CB5&0&08F0 -> configured [null] (ConfigFlags = 0x00000040). set: ROOTVOLMGR000 -> configured and started [volmgr.inf:ROOTVOLMGR,Volmgr] (ConfigFlags = 0x00000000). set: USBVID_0518&PID_0001&MI_017&33017F79&0&0001 -> configured and started [input.inf:USBClass_03&SubClass_01,HID_Inst.NT] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D131&SUBSYS_00008086&REV_113&33FD14CA&0&00 -> configured and started [machine.inf:PCIVEN_8086&DEV_D131,NO_DRV] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_3B56&SUBSYS_00318086&REV_053&33FD14CA&0&D8 -> configured and started [hdaudbus.inf:PCICC_0403,HDAudio_Device.NT] (ConfigFlags = 0x00000000). set: ACPIPNP0A082&DABA3FF&1 -> configured and started [machine.inf:*PNP0A08,PCI_DRV_ROOT] (ConfigFlags = 0x00000000). set: PCIVEN_11AB&DEV_6145&SUBSYS_424B8086&REV_A14&282E555F&0&00E7 -> configured and started [mshdc.inf:PCICC_0101,pciide_Inst] (ConfigFlags = 0x00000000). set: ROOTBASICDISPLAY000 -> configured and started [basicdisplay.inf:ROOTBasicDisplay,MSBDD_Fallback] (ConfigFlags = 0x00000000). set: ACPIPNP0C0E2&DABA3FF&1 -> configured and started [machine.inf:*PNP0C0E,NO_DRV] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_3B50&SUBSYS_424B8086&REV_053&33FD14CA&0&E7 -> configured and started [machine.inf:PCIVEN_8086&DEV_3B50,PCI_DRV] (ConfigFlags = 0x00000000). set: ROOTMS_NDISWANIP000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: USBVID_06CD&PID_01216&E0DF388&0&7 -> configured [null] (ConfigFlags = 0x00000040). set: ROOTMS_SSTPMINIPORT000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: ROOTMS_AGILEVPNMINIPORT000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: ACPIPNP00033&33FD14CA&0 -> configured [machine.inf:*PNP0003,NO_DRV_PIC] (ConfigFlags = 0x00000000). set: ACPIPNP00004&FADA1B8&0 -> configured [machine.inf:*PNP0000,NO_DRV_PIC] (ConfigFlags = 0x00000000). set: USBROOT_HUB5&A1C79AC&0 -> configured and started [usbport.inf:USBROOT_HUB,ROOTHUB.Dev.NT] (ConfigFlags = 0x00000000). set: ROOTCOMPOSITEBUS000 -> configured and started [CompositeBus.inf:ROOTCompositeBus,CompositeBus_Device.NT] (ConfigFlags = 0x00000000). set: ROOTVDRVROOT000 -> configured and started [vdrvroot.inf:ROOTvdrvroot,VDRVROOT] (ConfigFlags = 0x00000000). set: PCIVEN_10DE&DEV_0615&SUBSYS_15431462&REV_A24&1FC226EC&0&0018 -> setting CONFIGFLAG_REINSTALL on non-started device. set: ROOTSPACEPORT000 -> configured and started [spaceport.inf:RootSpaceport,Spaceport_Install] (ConfigFlags = 0x00000000). set: IDECDROMPLEXTOR_DVDR___PX-880SA_________________1.00____5&1A6F50F9&0&0.0.0 -> configured and started [cdrom.inf:GenCdRom,cdrom_install] (ConfigFlags = 0x00000000). set: USBVID_0518&PID_00016&C450EC6&0&5 -> configured and started [usb.inf:USBCOMPOSITE,Composite.Dev.NT] (ConfigFlags = 0x00000000). set: HIDVID_0518&PID_0001&MI_01&COL018&347AEDCC&0&0000 -> configured and started [msmouse.inf:HID_DEVICE_SYSTEM_MOUSE,HID_Mouse_Inst.NT] (ConfigFlags = 0x00000000). set: ROOTKDNIC000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: PCIVEN_8086&DEV_3B3C&SUBSYS_424B8086&REV_053&33FD14CA&0&D0 -> configured and started [usbport.inf:PCIVEN_8086&DEV_3B3C,EHCI.Dev.NT] (ConfigFlags = 0x00000000). set: STORAGEVOLUMESNAPSHOTHARDDISKVOLUMESNAPSHOT1 -> configured and started [volsnap.inf:STORAGEVolumeSnapshot,volume_snapshot_install.NTamd64] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D157&SUBSYS_00000000&REV_113&33FD14CA&0&42 -> configured [machine.inf:PCIVEN_8086&DEV_D157,NO_DRV] (ConfigFlags = 0x00000000). set: USBROOT_HUB204&3212B5C0&0 -> configured and started [usbport.inf:USBROOT_HUB20,ROOTHUB.Dev.NT] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_3B30&SUBSYS_424B8086&REV_053&33FD14CA&0&FB -> configured [machine.inf:PCIVEN_8086&DEV_3B30,NO_DRV] (ConfigFlags = 0x00000000). set: ROOTMS_NDISWANIPV6000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: PCIIDEIDECHANNEL5&12C6A84C&0&0 -> configured and started [mshdc.inf:Internal_IDE_Channel,atapi_Inst] (ConfigFlags = 0x00000000). set: PCIIDEIDECHANNEL5&12C6A84C&0&1 -> configured and started [mshdc.inf:Internal_IDE_Channel,atapi_Inst] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_3B02&SUBSYS_424B8086&REV_053&33FD14CA&0&F8 -> configured and started [machine.inf:PCIVEN_8086&DEV_3B02,MSISADRV] (ConfigFlags = 0x00000000). set: ACPIPNP0C044&FADA1B8&0 -> configured [machine.inf:*PNP0C04,NO_DRV_X] (ConfigFlags = 0x00000000). set: HIDVID_0518&PID_0001&MI_008&10A3B00A&0&0000 -> configured and started [keyboard.inf:HID_DEVICE_SYSTEM_KEYBOARD,HID_Keyboard_Inst.NT] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_10F0&SUBSYS_00008086&REV_053&33FD14CA&0&C8 -> setting CONFIGFLAG_REINSTALL on non-started device. set: ROOTUMBUS000 -> configured and started [umbus.inf:rootumbus,UmBusRoot_Device.NT] (ConfigFlags = 0x00000000). set: USBVID_1608&PID_000FV53491764-0 -> configured [null] (ConfigFlags = 0x00000040). set: SW{EEAB7790-C514-11D1-B42B-00805FC1270E}ASYNCMAC -> setting CONFIGFLAG_REINSTALL on non-started device. set: ROOTACPI_HAL000 -> configured and started [hal.inf:acpiapic,ACPI_AMD64_HAL] (ConfigFlags = 0x00000000). set: USBVID_050D&PID_706A7&1EED82DA&0&4 -> configured and started [usb.inf:USBClass_09,StandardHub.Dev.NT] (ConfigFlags = 0x00000000). set: HIDVID_0518&PID_0001&MI_01&COL028&347AEDCC&0&0001 -> configured and started [input.inf:HID_DEVICE,HID_Raw_Inst.NT] (ConfigFlags = 0x00000000). set: USBVID_0403&PID_6001A800ENCZ -> configured [null] (ConfigFlags = 0x00000040). set: PCIVEN_1033&DEV_00E0&SUBSYS_00E0131F&REV_044&2CFE2CB5&0&02F0 -> configured and started [usbport.inf:PCICC_0C0320,EHCI.Dev.NT] (ConfigFlags = 0x00000000). set: ACPIPNP01004&FADA1B8&0 -> configured [machine.inf:*PNP0100,NO_DRV_X] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D138&SUBSYS_00008086&REV_113&33FD14CA&0&18 -> configured and started [machine.inf:PCIVEN_8086&DEV_D138,PCI_DRV] (ConfigFlags = 0x00000000). set: STORAGEVOLUME{CE8B9D2B-835D-11E2-BE65-806E6F6E6963}#0000000015F00000 -> configured and started [volume.inf:STORAGEVolume,volume_install.NTamd64] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D151&SUBSYS_00000000&REV_113&33FD14CA&0&81 -> configured [machine.inf:PCIVEN_8086&DEV_D151,NO_DRV] (ConfigFlags = 0x00000000). set: ACPI_HALPNP0C08 -> configured and started [acpi.inf:*PNP0C08,ACPI_Inst.NT] (ConfigFlags = 0x00000000). set: HTREEROOT -> setting CONFIGFLAG_REINSTALL on non-started device. set: Failed to set SPDRP_CONFIGFLAGS property for HTREEROOT (0x0000000D) set: ROOTBASICRENDER000 -> configured and started [basicrender.inf:ROOTBasicRender,BasicRender] (ConfigFlags = 0x00000000). set: USBVID_050D&PID_07066&E0DF388&0&4 -> configured and started [usb.inf:USBClass_09,StandardHub.Dev.NT] (ConfigFlags = 0x00000000). set: ROOTMS_PPTPMINIPORT000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: USBVID_8087&PID_00205&31B4FE75&0&1 -> configured and started [usb.inf:USBClass_09,StandardHub.Dev.NT] (ConfigFlags = 0x00000000). set: USBVID_8087&PID_00205&2E10D338&0&1 -> configured and started [usb.inf:USBClass_09,StandardHub.Dev.NT] (ConfigFlags = 0x00000000). set: ACPIFIXEDBUTTON2&DABA3FF&1 -> configured and started [machine.inf:ACPIFixedButton,NO_DRV] (ConfigFlags = 0x00000000). set: USBROOT_HUB5&2D1E1C09&0 -> configured and started [usbport.inf:USBROOT_HUB,ROOTHUB.Dev.NT] (ConfigFlags = 0x00000000). set: ROOTMS_NDISWANBH000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_0 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_1 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_2 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_3 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_4 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_5 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_6 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: ACPIGENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_30_-_INTEL(R)_CORE(TM)_I7_CPU_______K_875__@_2.93GHZ_7 -> configured and started [cpu.inf:ACPIGenuineIntel_-_Intel64,IntelPPM_Inst.NT] (ConfigFlags = 0x00000000). set: PCIVEN_104C&DEV_8023&SUBSYS_424B8086&REV_004&2CFE2CB5&0&18F0 -> configured and started [1394.inf:PCIVEN_104C&CC_0C0010,Generic.Install.NT] (ConfigFlags = 0x00000000). set: ACPIPNP0C14MXM2 -> configured and started [wmiacpi.inf:*pnp0c14,WMIMAP_Inst.NT] (ConfigFlags = 0x00000000). set: HIDVID_0518&PID_0001&MI_01&COL038&347AEDCC&0&0002 -> configured and started [hidserv.inf:HID_DEVICE_UP:000C_U:0001,HIDSystemConsumerDevice] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D156&SUBSYS_00000000&REV_113&33FD14CA&0&41 -> configured [machine.inf:PCIVEN_8086&DEV_D156,NO_DRV] (ConfigFlags = 0x00000000). set: HDAUDIOFUNC_01&VEN_10EC&DEV_0889&SUBSYS_80860031&REV_10004&356EF690&0&0201 -> setting CONFIGFLAG_REINSTALL on non-started device. set: PCIVEN_8086&DEV_3B26&SUBSYS_424B8086&REV_053&33FD14CA&0&FD -> configured and started [mshdc.inf:PCICC_0101,pciide_Inst] (ConfigFlags = 0x00000000). set: USBROOT_HUB204&EF639EE&0 -> configured and started [usbport.inf:USBROOT_HUB20,ROOTHUB.Dev.NT] (ConfigFlags = 0x00000000). set: ACPIPNP08004&FADA1B8&0 -> configured [machine.inf:*PNP0800,NO_DRV_X] (ConfigFlags = 0x00000000). set: USBROOT_HUB205&3A21F57A&0 -> configured and started [usbport.inf:USBROOT_HUB20,ROOTHUB.Dev.NT] (ConfigFlags = 0x00000000). set: ACPIPNP01033&33FD14CA&0 -> configured [machine.inf:*PNP0103,NO_DRV_HPET] (ConfigFlags = 0x00000000). set: ROOTMS_L2TPMINIPORT000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: ROOTMS_PPPOEMINIPORT000 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: IDEDISKOCZ-VERTEX4_____________________________1.5_____5&2C297358&0&0.0.0 -> configured and started [disk.inf:GenDisk,disk_install.NT] (ConfigFlags = 0x00000000). set: ACPIPNP02004&FADA1B8&0 -> configured [machine.inf:*PNP0200,NO_DRV_X] (ConfigFlags = 0x00000000). set: PCIIDEIDECHANNEL4&3A9A829C&0&0 -> configured and started [mshdc.inf:Internal_IDE_Channel,atapi_Inst] (ConfigFlags = 0x00000000). set: PCIIDEIDECHANNEL4&3A9A829C&0&1 -> configured and started [mshdc.inf:Internal_IDE_Channel,atapi_Inst] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_3B34&SUBSYS_424B8086&REV_053&33FD14CA&0&E8 -> configured and started [usbport.inf:PCIVEN_8086&DEV_3B34,EHCI.Dev.NT] (ConfigFlags = 0x00000000). set: USBVID_0A12&PID_00016&E0DF388&0&6 -> setting CONFIGFLAG_REINSTALL on non-started device. set: USBVID_0556&PID_00017&1EED82DA&0&2 -> configured and started [usb.inf:USBCOMPOSITE,Composite.Dev.NT] (ConfigFlags = 0x00000000). set: ACPIPNP0B004&FADA1B8&0 -> configured and started [machine.inf:*PNP0B00,NO_DRV_X] (ConfigFlags = 0x00000000). set: ROOTMSSMBIOS000 -> configured and started [mssmbios.inf:ROOTmssmbios,MSSMBIOS_DRV] (ConfigFlags = 0x00000000). set: STORAGEVOLUME{CE8B9D2B-835D-11E2-BE65-806E6F6E6963}#0000000000100000 -> configured and started [volume.inf:STORAGEVolume,volume_install.NTamd64] (ConfigFlags = 0x00000000). set: USBVID_0556&PID_0001&MI_008&79DA2C1&0&0000 -> setting CONFIGFLAG_REINSTALL on non-started device. set: USBVID_0518&PID_0001&MI_007&33017F79&0&0000 -> configured and started [input.inf:USBClass_03&SubClass_01,HID_Inst.NT] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D150&SUBSYS_00000000&REV_113&33FD14CA&0&80 -> configured [machine.inf:PCIVEN_8086&DEV_D150,NO_DRV] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_3B20&SUBSYS_424B8086&REV_053&33FD14CA&0&FA -> configured and started [mshdc.inf:PCICC_0101,pciide_Inst] (ConfigFlags = 0x00000000). set: ROOTSYSTEM000 -> configured and started [swenum.inf:rootswenum,SWENUM] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_244E&SUBSYS_424B8086&REV_A53&33FD14CA&0&F0 -> configured and started [machine.inf:PCIVEN_8086&DEV_244E,PCI_DRV] (ConfigFlags = 0x00000000). set: ROOTRDPBUS000 -> configured and started [rdpbus.inf:ROOTRDPBUS,RDPBUS] (ConfigFlags = 0x00000000). set: PCIVEN_8086&DEV_D158&SUBSYS_00000000&REV_113&33FD14CA&0&43 -> configured [machine.inf:PCIVEN_8086&DEV_D158,NO_DRV] (ConfigFlags = 0x00000000). set: DISPLAYDELD0151&8713BCA&0&UID0 -> setting CONFIGFLAG_FINISH_INSTALL on started device. set: PCIVEN_1033&DEV_0035&SUBSYS_131F131F&REV_434&2CFE2CB5&0&00F0 -> configured and started [usbport.inf:PCIVEN_1033&DEV_0035&CC_0C0310,OHCI_NEC.Dev.NT] (ConfigFlags = 0x00000000). set: PCIVEN_1033&DEV_0035&SUBSYS_131F131F&REV_434&2CFE2CB5&0&01F0 -> configured and started [usbport.inf:PCIVEN_1033&DEV_0035&CC_0C0310,OHCI_NEC.Dev.NT] (ConfigFlags = 0x00000000). <<< Section end 2013/03/02 11:24:26.031 <<< [Exit status: SUCCESS] >>> [Setup online Device Install (Hardware initiated) - ROOTMS_NDISWANIP000] >>> Section start 2013/03/02 11:24:17.654 dvi: {Build Driver List} 11:24:17.669 dvi: Searching for hardware ID(s): dvi: ms_ndiswanip cpy: Policy is set to make all digital signatures equal. dvi: Created Driver Node: dvi: HardwareID - MS_NdisWanIp dvi: InfName - C:WindowsSystem32DriverStoreFileRepository
etrasa.inf_amd64_11668ce943ffe03a
etrasa.inf dvi: DevDesc - WAN Miniport (IP) dvi: Section - Ndi-Mp-Ip dvi: Rank - 0x00ff0000 dvi: Signer Score - INBOX dvi: DrvDate - 06/21/2006 dvi: Version - 6.2.9200.16384 dvi: {Build Driver List - exit(0x00000000)} 11:24:17.747 dvi: {DIF_SELECTBESTCOMPATDRV} 11:24:17.747 dvi: Using exported function 'NetClassInstaller' in module 'C:Windowssystem32NetCfgx.dll'. dvi: Class installer == NetCfgx.dll,NetClassInstaller dvi: Using exported function 'WlanDeviceClassCoInstaller' in module 'C:Windowssystem32wlaninst.dll'. dvi: CoInstaller 1 == wlaninst.dll,WlanDeviceClassCoInstaller dvi: Using exported function 'WwanDeviceClassCoInstaller' in module 'C:Windowssystem32wwaninst.dll'. dvi: CoInstaller 2 == wwaninst.dll,WwanDeviceClassCoInstaller dvi: CoInstaller 1: Enter 11:24:17.747 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:17.747 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:17.747 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:17.747 dvi: {Select Best Driver} dvi: Class GUID of device remains: {4d36e972-e325-11ce-bfc1-08002be10318}. dvi: Selected: dvi: Description - [WAN Miniport (IP)] dvi: InfFile - [c:windowssystem32driverstorefilerepository
etrasa.inf] dvi: Section - [Ndi-Mp-Ip] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 11:24:17.747 ndv: Waiting for previous device install to complete. 11:24:17.747 ndv: {Core Device Install} 11:24:18.091 dvi: {DIF_ALLOW_INSTALL} 11:24:18.091 dvi: CoInstaller 1: Enter 11:24:18.091 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.091 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.091 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.091 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 11:24:18.091 dvi: {DIF_INSTALLDEVICEFILES} 11:24:18.091 dvi: CoInstaller 1: Enter 11:24:18.091 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.091 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.091 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.091 dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 11:24:18.091 dvi: {DIF_REGISTER_COINSTALLERS} 11:24:18.091 dvi: CoInstaller 1: Enter 11:24:18.091 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.091 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.091 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.091 dvi: {DIF_DESTROYPRIVATEDATA} 11:24:18.091 dvi: CoInstaller 1: Enter 11:24:18.091 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.169 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.169 dvi: Class installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0x00000000)} 11:24:18.169 dvi: Default installer: Exit dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 11:24:18.169 dvi: {DIF_INSTALLINTERFACES} 11:24:18.169 dvi: Using exported function 'WlanDeviceClassCoInstaller' in module 'C:Windowssystem32wlaninst.dll'. dvi: CoInstaller 1 == wlaninst.dll,WlanDeviceClassCoInstaller dvi: Using exported function 'WwanDeviceClassCoInstaller' in module 'C:Windowssystem32wwaninst.dll'. dvi: CoInstaller 2 == wwaninst.dll,WwanDeviceClassCoInstaller dvi: CoInstaller 1: Enter 11:24:18.169 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.169 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.169 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.169 dvi: Default installer: Exit dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 11:24:18.169 dvi: {DIF_INSTALLDEVICE} 11:24:18.169 dvi: CoInstaller 1: Enter 11:24:18.169 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.169 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.169 dvi: {Install DEVICE} dvi: {Writing Device Properties} dvi: Strong Name=netrasa.inf:db04a16c12c47d17:Ndi-Mp-Ip:6.2.9200.16384:ms_ndiswanip dvi: {Writing Device Properties - Complete} inf: AddService=NdisWan,2,Svc-Mp-NdisWan,Evt-Rasmsg (netrasa.inf line 233) dvi: Add Service: Modified existing service 'NdisWan'. dvi: {Install DEVICE exit (0x00000000)} dvi: Install Device: Removing device sub-tree. 11:24:18.169 dvi: Install Device: Removing device sub-tree completed. 11:24:18.184 dvi: Install Device: Restarting device. 11:24:18.184 dvi: Install Device: Restarting device completed. 11:24:18.184 dvi: Class installer: Exit dvi: CoInstaller 1: Enter (Post Processing) 11:24:18.215 dvi: CoInstaller 1: Exit (Post Processing) dvi: {DIF_INSTALLDEVICE - exit(0x00000000)} 11:24:18.215 dvi: {DIF_NEWDEVICEWIZARD_FINISHINSTALL} 11:24:18.215 dvi: CoInstaller 1: Enter 11:24:18.215 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.215 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.215 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.215 dvi: Default installer: Exit dvi: {DIF_NEWDEVICEWIZARD_FINISHINSTALL - exit(0xe000020e)} 11:24:18.215 ndv: {Core Device Install - exit(0x00000000)} 11:24:18.215 dvi: {DIF_DESTROYPRIVATEDATA} 11:24:18.215 dvi: CoInstaller 1: Enter 11:24:18.215 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.215 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.215 dvi: Class installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0x00000000)} 11:24:18.215 <<< Section end 2013/03/02 11:24:18.231 <<< [Exit status: SUCCESS] >>> [Setup online Device Install (Hardware initiated) - ROOTMS_SSTPMINIPORT000] >>> Section start 2013/03/02 11:24:17.654 dvi: {Build Driver List} 11:24:17.794 dvi: Searching for hardware ID(s): dvi: ms_sstpminiport cpy: Policy is set to make all digital signatures equal. dvi: Created Driver Node: dvi: HardwareID - MS_SstpMiniport dvi: InfName - C:WindowsSystem32DriverStoreFileRepository
etsstpa.inf_amd64_3c3ce122bac60307
etsstpa.inf dvi: DevDesc - WAN Miniport (SSTP) dvi: Section - Ndi-Mp-Sstp dvi: Rank - 0x00ff0000 dvi: Signer Score - INBOX dvi: DrvDate - 06/21/2006 dvi: Version - 6.2.9200.16384 dvi: {Build Driver List - exit(0x00000000)} 11:24:17.794 dvi: {DIF_SELECTBESTCOMPATDRV} 11:24:17.794 dvi: Using exported function 'NetClassInstaller' in module 'C:Windowssystem32NetCfgx.dll'. dvi: Class installer == NetCfgx.dll,NetClassInstaller dvi: Using exported function 'WlanDeviceClassCoInstaller' in module 'C:Windowssystem32wlaninst.dll'. dvi: CoInstaller 1 == wlaninst.dll,WlanDeviceClassCoInstaller dvi: Using exported function 'WwanDeviceClassCoInstaller' in module 'C:Windowssystem32wwaninst.dll'. dvi: CoInstaller 2 == wwaninst.dll,WwanDeviceClassCoInstaller dvi: CoInstaller 1: Enter 11:24:17.794 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:17.794 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:17.794 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:17.794 dvi: {Select Best Driver} dvi: Class GUID of device remains: {4d36e972-e325-11ce-bfc1-08002be10318}. dvi: Selected: dvi: Description - [WAN Miniport (SSTP)] dvi: InfFile - [c:windowssystem32driverstorefilerepository
etsstpa.inf] dvi: Section - [Ndi-Mp-Sstp] dvi: {Select Best Driver - exit(0x00000000)} dvi: Default installer: Exit dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 11:24:17.810 ndv: Waiting for previous device install to complete. 11:24:17.810 ndv: {Core Device Install} 11:24:18.356 dvi: {DIF_ALLOW_INSTALL} 11:24:18.356 dvi: CoInstaller 1: Enter 11:24:18.356 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.356 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.356 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.356 dvi: Default installer: Exit dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 11:24:18.356 dvi: {DIF_INSTALLDEVICEFILES} 11:24:18.356 dvi: CoInstaller 1: Enter 11:24:18.356 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.356 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.356 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.356 dvi: Default installer: Exit dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 11:24:18.356 dvi: {DIF_REGISTER_COINSTALLERS} 11:24:18.356 dvi: CoInstaller 1: Enter 11:24:18.356 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.356 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.356 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.356 dvi: {DIF_DESTROYPRIVATEDATA} 11:24:18.356 dvi: CoInstaller 1: Enter 11:24:18.356 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.356 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.356 dvi: Class installer: Exit dvi: {DIF_DESTROYPRIVATEDATA - exit(0x00000000)} 11:24:18.356 dvi: Default installer: Exit dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 11:24:18.356 dvi: {DIF_INSTALLINTERFACES} 11:24:18.356 dvi: Using exported function 'WlanDeviceClassCoInstaller' in module 'C:Windowssystem32wlaninst.dll'. dvi: CoInstaller 1 == wlaninst.dll,WlanDeviceClassCoInstaller dvi: Using exported function 'WwanDeviceClassCoInstaller' in module 'C:Windowssystem32wwaninst.dll'. dvi: CoInstaller 2 == wwaninst.dll,WwanDeviceClassCoInstaller dvi: CoInstaller 1: Enter 11:24:18.371 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.371 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.371 dvi: Class installer: Exit dvi: Default installer: Enter 11:24:18.371 dvi: Default installer: Exit dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 11:24:18.371 dvi: {DIF_INSTALLDEVICE} 11:24:18.371 dvi: CoInstaller 1: Enter 11:24:18.371 dvi: CoInstaller 1: Exit dvi: CoInstaller 2: Enter 11:24:18.371 dvi: CoInstaller 2: Exit dvi: Class installer: Enter 11:24:18.371 dvi: {Install DEVICE} dvi: {Writing Device Properties} dvi: Strong Name=netsstpa.inf:db04a16c165dcd8c:Ndi-Mp-Sstp:6.2.9200.16384:ms_sstpminiport dvi: {Writing Device Properties - Complete} inf: AddService=RasSstp,2,Svc-Mp-Sstp (netsstpa.inf line 51) dvi: Add Service: Modified existing service 'RasSstp'. dvi: {Install DEVICE exit (0x00000000)} dvi: Install Device: Removing device sub-tree. 11:24:18.371 dvi: Install Device: Removing device sub-tree completed. 11:24:18.387 dvi: Install Device: Restarting device. 11:24:18.387 dvi: Install Device: Restarting device completed. 11:24:18.387 dvi: Cla0 -
Kirk, I think your upload file was truncated.. Just select the end of the file starting with last current boot session then copy and past... AL, K0VM0
Thats the complete log file from setting up previous devices. Which is why it is listing NDIS and WAN entries. You can safely delete those log files and then run the installer again to see what results you get just for that install.0
Ok, i am just wondering if you have an underlying issue that may be causing this. May be worth while just running a quick System File Check to scan your windows system. From an Administrator command prompt: sfc /scannow This article will explain more. http://technet.microsoft.com/en-us/library/bb491008.aspx Also, you could try a clean boot. This will disable all unnecessary drivers / services and startup programs. Here is a KB article explaining how to do this. http://support.microsoft.com/kb/9291350
Based on the <<< [Exit status: SUCCESS] - this should not throw an error to the installer to stop. So your issue may be further down the install chain - this is where the MSIEXEC log would come in handy.0
Richard, Send me you direct e-mail to mycall at arrl dot net and i'll send you the msiexec log AL, K0Vm0
Email sent.0
Richard, Thanks. I think I've spent enough of yours and everybody's time on this issue. I do appreciate yours and everyone's comments and suggestions. I will do a system file check and if that fails will do a clean boot. If that doesn't provide anything will reinstall the OS and start fresh. Time consuming yes but far less time than we've all spent. Many thanks, Kirk, K6KAR0
No problem at all. I love a challenge - so was happy to try and help. There is something quirky going on. I can reproduce the failure I created every time now, but I don't think that is what you guys are seeing - otherwise the same fixes would have helped. Good luck!0
Richard, et.al, Just as a follow-up, rebuilding Win8 fixed the problem. CAT now loads without difficulty. Probably a cop-out on my part to not continue to trouble shoot but it only took me 15 minutes to reload the Win8 OS. Guess I'll always wonder what caused the problem in the first place. Again, many thanks to all of you for trying to help. Regards, Kirk, K6KAR Niceville. FL0
Nah, not a cop out. I can imagine how frustrating it was. This is one of the reasons why I always build my OS and apply the patches first - then create an image backup that I can revert to if an install goes south. It also means I can mount that image as a Virtual machine to test new software with before installing it on the live physical image. Glad you got it working.0
This issue ended up being a Win8 OS issue that an operating system rebuild resolved.0
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 745 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
