Need separate CAT installer for 0.15.13 under Win 8.
Tom
CAT Install with 0.15.13 in Windoze 8 I installed 0.15.13 tonite as administrator and am unable to get the associated CAT server to install. The Knob driver seems to work fine. Is the CAT installer available as a separate download? I had a similar problem with previous version but some how got it to install/ Tonite windows throws the following error report: ----------------------------------- Source Driver software installation Summary Could not install driver software Date 9/14/2013 11:44 PM Status Not reported Description Windows could not copy all of the files needed to install this device driver software. This sometimes happens when the driver software was not designed for this version of Windows. Problem signature Problem Event Name: PnPDriverImportError Architecture: x64 Win32 error: E000022F Inf name: flexcontrol.inf Driver Package hash: a5853b6b600df191375d7aaad3d16a1813fc3632 OS Version: 6.2.9200.2.0.0.768.101 Locale ID: 1033 Files that help describe the problem DMI765.tmp.log.xml LOG870.tmp flexcontrol.inf 73 de Tom, K3IO
After I followed the uninstall instructions for CAT, I installed the new SmartSDR and the program CAT seemed to disappear. I found it in the SmartSDR folder under modules. Since my system is a 64 bit base, CAT was installed using the CATInstaller_64 program. This reinstalled CAT and all is good now.0
Thanks to Al, K0VM I found where the installer resides: c:/program files/FlexRadio Systems/SmartSDR/Modules After it was installed, I found it listed in the Windoze PROGRAMS/STARTUP folder. 73, Tom0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
