6700 rear panel layout
K1UO Larry
Member ✭✭✭
Anyone got a link to a good printable (8 X 10) picture of the 6700 rear panel? Makes it handy when reaching behind the rig to plug/unplug cables without having to fully remove the radio to read the back panel.
Thanks Steve..... Once my Granddaughter manipulated the image for me the way I wanted.. this will work just fine! [ By 'manipulated' I mean she expanded the pic to a larger size and printed it Landscape] She loves it when I give her these little 'puter' chores.0
Either I have an off-breed 6500, or the picture you show is not correct. This got me into trouble when I first recieved my 6500. This one you show was in the original brochure at Dyaton 2012. Mine has the red RCA jacks in the upper row L-R marked 10 Mhz Output, TX1, TX2, TX3. The lower White row is REM ON, ALC, TXREQ, PTT L-R. This is looking down from above at the rear panel. Tell me if I am wrong! Marv W0ZK0
Marv, you are totally correct. I had forgotten that we changed the position of several of the RCA connections after we made that brochure. I do not have an updated picture of the back panel and of course what is printed on your back panel is correct. Sorry for the confusion.0
Thanks Marv for bringing that up.... The RCA jacks are exactly as you mentioned....guess I need a new picture to refrence... I didnt want to have to haul the rig completely out to be able to read the jack labelling.. just enough to connect cables and locate connectors by referring to the pic. I suppose there is always a dental mirror .. OR..I could wait for the operating manual ;-)0
I use a mirror and flashlight.0
I think the image in the F6000 Quick Start guide has the correct placment of the red/white jacks. http://support.flex-radio.com/Downloads.aspx?id=420 AL, K0VM0
Thanks Al, that copy came out really well on a landscaped 8 1/2 X11 sheet. If anyone wants a copy I can email the MS Word 2010 file.0
I would like one. dhankins@comcast.net0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
