Looking for CAT
Robin Haighton
Re V0.15. 13 I have loaded/unloaded Smart SDR 3 times looking for CAT (as described on page 8) but no such file exists I am running Windows 8 32 bit. any advice? Robin VE3FRH
Robin, if you go to Windows Explorer and click on Local Drive C, then select Program Files (x86) subfolder. In that subfolder there should be another subfolder called FlexRadio Systems. Click on that subfolder and you should find the SmartSDR CAT installation software. Hope this helps you out. Good Luck W1GLV1
Robin, You can also try running: C:/Programs Files/FlexRadio System/SmartSDR/Moduiles/Catinstaller_64.msi Subsistute for a 32 for 64 on a 32 bit system AL0
For Win8 you need to search for "SmartSDR CAT Setup" since there is no easy way to view the Start menu program folders.0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
