Filter width displayed is not correct in CW
Sergey R5AU
SSDR 0.15.13 filters width indication: selected indication 50 48 100 98 250 250 400 398 800 798 1.0 1.0 1,5 1,5 3,0 3,0 When you have selected CW with 50 Hz change mode on SSB and back - selection is: CW and 50Hz but indication width is 400 and real filter width is 400Hz Have not check yet any other combinations, has any body this same issues ?
2
Sergey, I also noticed the number difference when in CW but figured it was a rounding error. Regards, Al0
Al, i don't think so, lets set mouse cursor on the PAN down with selected frequency, you can see low and hight filter cuts where exactly frequency number end on 9, This issue appers in case moving between witdh, in case first time entering into the mode the first time indication is right. Can you check on you radio? My toy is 67000
I think it should be addressed as trouble ticket0
I have entered a defect for this behavior. Thanks for the report and the follow up confirmation.0
- 372 Community Topics
- 95 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 783 Peripherals & Station Integration
- 997 Third-Party Software
