Creating my own persistence...
Richard G7EIX
Just thought I would share.... and it may give some ideas to other tinkerers until the API becomes available. I play a little with WPF and also automation - so I decided to take a look at SmartSDR as it is a WPF client. I have successfully created a little app that runs and waits for SmartSDR to fire up and go to 14.100mhz - it will then inject my Equalizer settings that I saved, the MIC settings and other options. I did this with Snoop and TestStack / White. http://snoopwpf.codeplex.com/ https://github.com/TestStack/White Once I tidy it up a bit and give it an interface I will show it in more detail - but its a good interim for me until we get basic persistence.
4
Much appreciated as I have some other uses in mind. Would also like to do sequenced start-up/shut-downs, so all ears for suggestions. 73 Steve K9ZW0
Excellent Richard. Looking forward to seeing more on this.0
Keep us informed, great idea. Thanks Al N4AB0
I have a working applet now that pulls all the selections for ALL the CheckBoxes and Buttons - just working on a way to delve into the Equalizer DataContext to pull those settings. Pity I have to work today - otherwise I would play a little more. There is always the weekend.0
Well, I now have my own Persistence working. I'm not going to develop this much further though as it will hopefully be a moot point in the coming month and really not worth the effort. Pulling the data was a bit of a chore as a lot of the WPF elements are not named (the EQ) and it required trolling through an index of sliders to pull the data - and this takes time (cpu cycles) and locks up the software for a second while TestStack trolls the elements. It was a fun little project - but I'll wait for the API before I create something that others may find of use. For now...back to work!1
- 322 Shack Infrastructure
- 227 Networking
