Determining Exact Receive Frequency in mHz
John Stuart KM6QX
For years I have used my Flex-1500 to measure received carrier frequencies to the nearest millihertz. This required correcting for the F-1500 DDS's offset at each VFO frequency. I understand that this is significantly more complicated with the 6000 series, but possibly the exact Rx and Tx frequencies could be calculated internally by the firmware. If that were to be done, could the exact 'VFO' frequencies then be read with a new, or modified CAT command? This would satisfy us FMT nuts and not require any SmartSDR enhancements. John Stuart, KM6QX
4
The specifications of the FLEX-6000 is to report frequency in 1 Hz increments.0
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
