Shut PowerSDR down while transmitting, F6700 continues transmitting
K2CM
K2CM Member ✭✭
edited March 2017 in SmartSDR for Windows
14.100, Key the Mike, x out of PowerSDR, Transmitter stays on. Same issue that occurs when you are in tune mode.
  • Tim - W4TME
    edited March 2017
    Yes, it does. This is a confirmed behavior and we have a defect listed in the developer's bug tracker to investigate and some up with a solution to this issue.
