Spectrum doesn't come up after closing one of two slices. 6500 V13.10
k0eoo
Member ✭✭✭
I don't know if this has already been reported. When I have two slices showing with one RX each up for several hours and switch between the two slices tor TX and make a few contacts, and then I close one of the slices then open it again, The slice opens but with no spectrum running. This has happened three or four times now.... Dennis, k0eoo
2
I have had similar things happen several times. I open a Pan window and the frequency scale is there. I can slide it, zoom/unzoom it, but there is not activity, no traces, and I can't open a receiver slice. Some other times I have opened it and heard static and can tune a receive slice, but there is no trace, no matter how much I adjust the RH panel. I have not yet been able to correlate any behavior that causes it, other than having been on two slices in two different pan windows and then closing one before trying to open another one.0
Interesting, I just had this happen to me today with 4 panadapters actively running, then trying to switch one from 10m to 6m using the band select buttons. There was no spectrum trace when I switched to 6m. This was after the radio had been running for roughly 4 hours straight. All was well after rebooting the radio. This is on a 6700 with the GPSDO and V0.13.10 SSDR. Keith - AE5XN0
See my post in another thread. It has to do with having 80 & 40 open at the same time causing other bad things to happen.0
Does Flex have an official response to this problem?0
We do and it has been posted on other topics. We have this and other reports of issues like this, primarily with the 6500 entered into our bug tracker for resolution.0
- 112 SmartSDR+
- 944 Maestro
