Speaker Mute state not reset on startup.
edited September 2019 in SmartSDR for Windows
If you mute SmartSDR and then close down the app and then re-open, the Mute state stays as muted but the icon comes up as unmuted. You have to click the speaker twice to get it back to correct state. Before I close down... When I start SmartSDR again (radio was not power cycled). But no audio until I do a quick toggle.
Welcome!
  • Member ✭✭
    I believe that this issue along with PSDR remembering your settings, is being worked on. I think the title of the main post is something like "persistence". When I power down my 6700, nothing is remembered.
  • Member ✭✭
    edited March 2015
    I did not categorize this as a persistence issue as I would expect the radio to reset the state of mute to unmute when I disconnect - as opposed to retaining it - which is keeping it persistant - which the software currently lacks. And yes, if I close the client and power down the mute is no longer in effect. But if I just close the software and then re-open it on the same machine or another machine the muted state is retained. So at this time I am going to assume that its the client software not resetting the speaker to a default state as it does with the bands and other settings.
  • Member ✭✭✭
    edited March 2017
    My guess is that the setting that isn't being reset is local to the client - a computer thing - rather than a software setting. What may be happening is the restarted SmartSDR lacks an initial state set-&-check routine. 73 Steve K9ZW
  • Member ✭✭
    edited March 2015
    Exactly my thoughts.
  • Administrator, FlexRadio Employee admin
    edited March 2017
    I have entered this behavior into the developer's bug tracker for additional investigation. Thanks for reporting it Richard.
