Speaker Mute state not reset on startup.
Richard G7EIX
If you mute SmartSDR and then close down the app and then re-open, the Mute state stays as muted but the icon comes up as unmuted. You have to click the speaker twice to get it back to correct state. Before I close down...
When I start SmartSDR again (radio was not power cycled).
But no audio until I do a quick toggle.
I believe that this issue along with PSDR remembering your settings, is being worked on. I think the title of the main post is something like "persistence". When I power down my 6700, nothing is remembered.0
I did not categorize this as a persistence issue as I would expect the radio to reset the state of mute to unmute when I disconnect - as opposed to retaining it - which is keeping it persistant - which the software currently lacks. And yes, if I close the client and power down the mute is no longer in effect. But if I just close the software and then re-open it on the same machine or another machine the muted state is retained. So at this time I am going to assume that its the client software not resetting the speaker to a default state as it does with the bands and other settings.0
My guess is that the setting that isn't being reset is local to the client - a computer thing - rather than a software setting. What may be happening is the restarted SmartSDR lacks an initial state set-&-check routine. 73 Steve K9ZW0
Exactly my thoughts.0
I have entered this behavior into the developer's bug tracker for additional investigation. Thanks for reporting it Richard.1
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 150 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 937 Third-Party Software
