Lost connection - > Unhandled Error
Sergey R5AU
Well , after 2 weeks playing with with my 6700 i have found Unhandled Error, this error appear in case any lost connection between radio and SSdr, restart of the SSDR make no sense just one more Undanled Error appear. Back to the live only via Off/On 6700. OS-Win7 64bit, running on the VMware Fusion.
I have found this is the case where the F6.7K is shut down while SmartSDR is still running. It doesn't seem to cause any problems, so I don't think a correction is needed at this time. If you shut down SmartSDR before you shut down the radio, you will not get this error. Just mentally change this message to "You shut down the radio before shutting down the software, don't do this!"0
You are right "You shut down the radio before shutting down the software, don't do this!" , but the issue appearing in case lost connection(in any cases: cable plug out, ethernet problems etc) between 6700 and SSDR, and 6700 still running (recieving signal etc) but no new connection are possible before 6700 Off/On(always message error appears). I assume rutine with connection testing should run on 6700 to set radio in initial state in case lost connectivity with SSDR?0
This is a previously reported issue that is being addressed. Thanks for the report.0
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
