Another Persistance Question
Nick
Another basic persistance question. Will the saved data be on the PC or the radio? If on the PC will we be able to save and load different profiles?
2
I would expect the radio settings and eq/mic to be saved on the radio so that you can use the same settings across multiple clients and multiple machines. I am sure that client specific settings will also be saved on the local machine. And then once DAX comes into play you have a whole other array of client specific settings to cater for which would to be saved locally on a client/pc by client/pc basis.2
Nick, The data will be saved on the radio for now -- everything except things specifically related to the client such as window size/placement/etc. The idea here is that later when you may have a network device and a local LAN device, you can make a change and have it reflected both places. We'll look into allowing you to move them around along with profiles in the Persistence roadmap item scheduled for later. Steve0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
