Slice A & B offcreen warning arrows overlap one another...
Ken - NM9P
Member ✭✭✭
If I have 2 slices on the same pan window and drag the pan to either side so that both slices are off screen, the little warning notifications on the right or left side of the pan will overlap each other, rendering them unreadable. I would suggest that each slices "off screen" indicator should be at a different height to eliminate or reduce overlap.
Yes, this is a known defect that has been reported previously. It is slated to be fixed in a future version of SmartSDR. Thank you for reporting it.1
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
