ATU behavior between 15m and 17m bands
Michael N6BRP
Michael N6BRP Member
edited March 2017 in SmartSDR for Windows
Just noticed that when switching between 15 and 17m, ATU does not switch to byp. Seems to work properly switching back and forth from other bands. Not sure if this has been previously reported.
  • Tim - W4TME
    edited March 2017
    What version of SmartSDR are you using?
  • Michael N6BRP
    edited March 2017
    I'm using version 0.13.10, Windows 7 Ultimate. Noticed no ATU problems switching between the other bands..... only 17 and 15 -Mike
  • Michael N6BRP
    edited February 2017
    Has anyone else noticed this behavior, or am I the only one?
  • Dave - WB5NHL
    Dave - WB5NHL Member ✭✭
    edited December 2014
    Software 0.13.10 I just switch from 15m (ATU-Success) to 17m (ATU-Success). Yup you are right. I should have had BYP when I switched to 17m and didn't. Inverse same thing. Tune showed SWR way to high until ATU pressed. Good catch Mike
  • Michael N6BRP
    Thanks Dave: You got it; I forgot to add that you have to engage the ATU (sucess) on the initial band before the behavior shows up. -Mike
  • Michael N6BRP
    Hope this doesn't slip through the cracks, no acknowledgement so far
  • Tim - W4TME
    edited December 2016
    Wait until the next version of SmartSDR (hint, hint)
  • Roger Rockwell/na4rr
    Roger Rockwell/na4rr Member ✭✭
    I tried it and got the same results as Michael Roger
  • Michael N6BRP
    edited August 2013
    Thanks Tim
