How do I change Monitor Volume in CW Mode without changing overall Volume
Ken W9IE
Ken W9IE Member ✭✭
edited January 2020 in SmartSDR for Windows
I cannot find a slider or level adjustment for only the monitor level or volume Or am I missing something Ken W9IE
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    There is no adjustment at this time.. Jim K4JAF
  • Tim - W4TME
    edited March 2017
    Jim is right. We have not implemented that feature in SmartSDR yey.
  • W5XZ - dan
    W5XZ - dan Member ✭✭
    edited January 2020
    I have found a temporary work-around for lack of sidetone volume adjust on cw...IF you use speakers ( i know, heresy on cw...but i give Cindy QSK )...there are two audio volume controls...one in the top right corner of the GUI, 'master' i guess?...and another in the speaker drop down menu...seems the 'master' affects monitor volume, but the slice speaker does not...turn the 'master' down, and the slice audio up... still juggling AGC-t values... JM2C...73
  • DonS
    DonS Member ✭✭✭
    edited August 2013
    how are you adjusting AGC-T on the 6x00 radio?
  • W5XZ - dan
    edited December 2016
    it's the bottom slider in the speaker drop down menu...default of 50 is usually too high, IMHO
  • DonS
    DonS Member ✭✭✭
    edited August 2013
    I assume you are referring to the slice speaker not the general speaker in the upper right corner of the screen.
