How do I change Monitor Volume in CW Mode without changing overall Volume
Ken W9IE
I cannot find a slider or level adjustment for only the monitor level or volume Or am I missing something Ken W9IE
2
There is no adjustment at this time.. Jim K4JAF0
Jim is right. We have not implemented that feature in SmartSDR yey.0
I have found a temporary work-around for lack of sidetone volume adjust on cw...IF you use speakers ( i know, heresy on cw...but i give Cindy QSK )...there are two audio volume controls...one in the top right corner of the GUI, 'master' i guess?...and another in the speaker drop down menu...seems the 'master' affects monitor volume, but the slice speaker does not...turn the 'master' down, and the slice audio up... still juggling AGC-t values... JM2C...730
how are you adjusting AGC-T on the 6x00 radio?0
it's the bottom slider in the speaker drop down menu...default of 50 is usually too high, IMHO0
I assume you are referring to the slice speaker not the general speaker in the upper right corner of the screen.0
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 29 SmartSDR+
- 6.3K SmartSDR for Windows
- 415 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 222 FLEX-8000 Signature Series
- 928 Maestro
- 902 Genius Products
- 325 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 982 Third-Party Software
