split operation both panadapters and slices stopping working freezing up.
Reggie-k6xr
While operating split on 20 meters this afternoon in the qrp fox hunt, both slices and the panapters froze up and I had to turn 6500 off and reboot to get radio back to normal. first time this has happened.
Did you change the antenna port or anything else when this happened?0
No not to my knowledge.0
I have the same problem with my FLEX 6500. While operating split on 15 meters, I was using Slice a set for "A" TX sand one Slice for "B" Receive. Adjusting the ATU, both slices and the panapters froze up. I had to turn 6500 off and reboot to get radio back to normal.This appears to be a SPLIT issue with the new FLEX. I was trying to operate 21.028 Transmit and 21.030 Receive. Mode was CW for both slices. This problem has occurred every time I attempt to operate SPLIT. I am running the latest SmartSDR version.0
I had this happen with just one slice open; but, traced the problem to RF feedback into the computer and router. I put ferrite cores on both ends of the cable from the Flex to the router, RF cores on all cables into the computer, and have a couple of spares on the desk.... So far, no hangups0
I also have RF Chokes on all my cables. I noticed that if you are splitting the transmit frequency close to the receive frequency of the second split receiver, it will lock up both displays. The Split Receive will show MAX RF signal before it locks up. Several attempts at running CW Split have worked as long as I set Split "A" to Receive and Split "B" to transmit. I am running the same antenna on both Transmit and Receive. Split operation in Digital will function using one Slice. This appears to be a function of the DM-780 software which runs with the new FLEX. Will keep trying different Slice functions to see if it will continue to work for CW. Thanks0
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
