ATU behavior between 15m and 17m bands
Michael N6BRP
Just noticed that when switching between 15 and 17m, ATU does not switch to byp. Seems to work properly switching back and forth from other bands. Not sure if this has been previously reported.
What version of SmartSDR are you using?0
I'm using version 0.13.10, Windows 7 Ultimate. Noticed no ATU problems switching between the other bands..... only 17 and 15 -Mike0
Has anyone else noticed this behavior, or am I the only one?0
Software 0.13.10 I just switch from 15m (ATU-Success) to 17m (ATU-Success). Yup you are right. I should have had BYP when I switched to 17m and didn't. Inverse same thing. Tune showed SWR way to high until ATU pressed. Good catch Mike0
Thanks Dave: You got it; I forgot to add that you have to engage the ATU (sucess) on the initial band before the behavior shows up. -Mike0
Hope this doesn't slip through the cracks, no acknowledgement so far0
Wait until the next version of SmartSDR (hint, hint)0
I tried it and got the same results as Michael Roger0
Thanks Tim0
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
