no transmit on 6500
Kennth Blanton
On the Flex 6500 loaded up smartSDR for first time today .. receiver works apparently, but no output on transmit into dummy load. tuner works and indicates success, but speaking into mic indicates 20 watts and no more , even on AM
In Tune mode, can you move the power to the right and see full power? How about CW? What microphone are you using? In many cases, the +20db button needs to be pressed for full output - is the modulation meter fully deflecting? By the way, I believe AM operation is not recommended at this time. Good luck & welcome to the 6500 club!1
AM transmit isn't implemented in 0.13.10 software. George is right, check the +20db button and slide the mic gain up.1
From page 6 of the 0.13.10 release notes: "6. Only transmitting on USB/LSB and CW is supported. Do not transmit on AM" Read the release notes. The radio you save may be your own.
- 654 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
