Ethernet Lightning Surge Protection
About 3 years ago we suffered a direct lightning strike to our SteppIR 4EL yagi. Although inconvenient and somewhat expensive the damage to the antenna was minor compared to all the other damage. Without going into all the details, most damaged was caused by lightning generated conductive coupling to a couple of CAT 5 runs . As part of the repair process, I ran FO from the man part of our home out to the station computers. This has proved to not only be very effective but eliminated any further potential lightning damage. This isn't the only thing that was done. We've since made major improvements to (hopefully) offset further lightning damage. The cost for repair and or replacement came to over $22K. Fortunately, a great deal of this was covered by insurance. 73, Kirk, K6KAR0
Kirk, I remember talking about it with you. And that is one reason I'm looking at the fiber link. Last year I lost an ethernet board in one of my servers here from a "nearby" (not direct) strike Also lost a PolyCom speaker phone from a spike on the phone cable. I have a lot of lightning mitigation in place but the phone and Cat5 cabling are still a weak point. Everything else survived and all of the ground rods, thousands of feet of copper wire, wholehouse surge protection and lightning rods on the roof did their job. Unless the ethernet on the radio is on an easily replaceable daughter board, it seems like the fiber link is a worthwhile investment for any of us that live in thunderstorm prone areas. Regards, Al / NN4ZZ0
Al, Your shopping looks fine to me. With your selection, you get a built-in 4-port switch in the shack end of the circuit. We use some pretty generic Startech media converters here at the office to pass our network in to and out of a screen cage without compromising the -110 dB of shielding.0
Currently in my setup i am using isolation with Wi-Fi (802.1n)instead fiber optics as described on picture by Al, due to Wi-Fi GPON router was installed by provider. As extender in use http://netgear.com/home/products/wireless-range-extenders/WN2000RPT.aspx1
Priwet, Segey ! so, the WN2000RPT is in the hamshack, one cat5 ethernet cable to radio, another cat5 ethernet cable to hamshack pc ? and, it communicates with a separate wifi / router / dsl modem for internet access? some Netgear devices have history of generating RFI, i think. more ferrite, perhaps? DSW, Dan0
Well Den (sounds good: Priwet !), you are right: ZTE F660 GPON router deliver Ethernet cable for NAS+ Wi-Fi for family devices:-) + Wi-Fi for the Shack network, where - WN2000RPT as extender with DHCP server+iMAC, printer connected with Wi-Fi too. Before you note regarding RFI, i never hear it before, just 5 min ago check it with my F6700 - no doubts, without RFI for now. P.S. link speed ZTE->NetGear: 120mbit/s - quite enough for operations on distance abt 15 meters in my flat.0
Fiber protection for LAN to Flex. I wanted to isolate the Flex from any exposure to copper LAN throughout the house. Additionally, I wanted to isolate the entire LAN from the evils of the copper MaBell outside world. Additional wireless was not an option and I didn't want to disturb the existing LAN more than necessary. See pictures below (hopefully) for one 6 ft fiber link inserted between the Flex and a 8 port LAN Sw using TP Link converters (MC100CM) and multi-mode fibers. A second 6 ft fiber link was inserted between the DSL modem and the Router. I'll sacrifice cheap gadgets to protect the Flex. All is working just fine and no speed impact. The converters were only $33 ea and it takes just a few minutes to install. Bob AJ4VE1
Bob, Nice setup. I was looking at separate fiber links also but decided the 4 port CAT5 switch with a Fiber port would work better for me. I needed multiple ports in the shack for the radio computer and printer. It was a little less cost overall to use one fiber link for isolation and the short CAT5 patch cables from the switch. I should have it installed in a day or two (waiting on one more component). Do you mind if I copy your pictures and notes for future reference? Regards, Al0
Al, In my case I already had an extensive network in place (6 pc's + server) and just needed the isolation. If I were starting from scratch I would probably go the same route as you describe. No problem copying the pics, etc. Good luck with your fiber project. 73 Bob0
Thanks Bob, I created a word document with your notes and pictures. If you would like to see it, send me a note at al@nnzz.com. Regards, Al / NN4ZZ0
sergey: i think i will try it. no climbing in my hot attic! and only $66 at local stores.0
I received the parts today and hooked it up in 5 minutes. I connected the existing CAT5 cable that went to my PC to the fiber converter. Then connected a 6 foot fiber patch cable from the converter to the 4 port switch. And finally a short CAT5 patch cable goes from the switch to the PC. The 6700 arrives this week and there is a patch cable from the switch ready to plug into the 6700. So far it is working fine.....1
Update -- this has been in place for about 2 years and was plug, play and forget. Cheap insurance for the ethernet controller in the 6700.
Lightning protection and RF mitigation in one.
http://www.nn4zz.com/FLEX6700.htm#Ethernet_Lightning_Protection
If you don't need the extras ports in the shack you can just buy a pair of the converters for the connection to the radio.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com0 -
I've added a lower cost version of Al NN4ZZ's system, which appears to be working quite well.
Middle son Winston KC9FVR helped test things. Worked out to $91.00, with a complete set held as spares in reserve. (Only $41.50 is in use)
Write up at: https://k9zw.wordpress.com/2017/05/25/adding-ethernet-lightning-protection-to-the-k9zw-shack/
Steve K9ZW
If your already on Verizon FIOS (fiber to the house) other then a direct home hit your protected on the network side .. you just have to protect all the other places it can get you... power is the main everyone thinks of.. however most damage comes from ground... FYI0
Careful David, as you can unexpectedly introduce paths to FIOS system anywhere after the ONT Box (I think "Optical Network Termination" - where the Fiber ends and your system starts):
If the Box is outside it can be an energizing point of origin.
ANYTHING powered that also plugs by cabled Ethernet into your home network can energize that wiring in certain circumstances. (Think computer power supplies and all sorts of that sort of stuff).
And if your in-the-house wiring is the typical install you have induction coupling and overly close proximity risks with other wiring that could be energized.
To reduce RFI you might end up either using ferrites or decoupling like this technique.
Expect there may be others I've not thought of in this quick further comment.
Appreciate the reminder about FIOS as we cannot get it where I live.
Steve K9ZW
Steve.... ONT = Optical Network Terminal
The only thing that goes into the box from "down line" is a fiber, no copper, so the box would have to be "energized" i.e. a direct strike to the side of your home. It's not like Cable coming into your home. A cable box down the street or a neighbors house even could take a strike and you could still be effected by that copper cable just like an electric power pole down the road.
To your point (and mine), ANYTHING powered from the wall (electric) is a point of concern, even these fiber converters, they use a power source (both ends) so to my point is IF you take a direct hit, whats going to stop the strike from traveling down the electrical outlet to the power supply into the fiber converter on the end you are trying to protect, down the Ethernet cable (twisted pair) into the device you are trying to protect?
I guess what I'm saying is, this device will only stop 1 path and one possibility and there are many many others to be concerned with.
Sorry about the FIOS thing, I wish everyone could get it, either that or Google FIBER would get off their tookis and get their infrastructure in place.0 -
Thank you for the reminder. I have that side somewhat protected, but forgot to explain it, and edited my write up to include that protection need.
Steve K9ZW
- 310 Community Topics
- 566 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 385 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 108 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 841 Genius Products
- 433 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 266 Shack Infrastructure
- 187 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
