SmartCat Install Procedure
geep
I think there is a small error in the version .13 PDF notes in regard to the location and execution of the cat file. It is located where the docs indicate but is in another subfolder called "modules." The filename is also incorrect, should be catinstaller_64.msi ( in my case on a 64 bit machine). This could be pretty confusing for an inexperience or first time user. It was for me and I am a long time Flex user. geep wa4rts
I was just beginning to wade through that section of the release notes when I saw your comment. Probably just an oversight on the editing of the prior release note to this new version. Although I never did install the 0.12.17 SmartCAT, so can't verify that it was OK in that version.0
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
