Audio hiss with narrow filters
K2CM
When I narrow the filters down to 100 or 50 hz, I get audio hiss. The copy ability would be vastly improved if this hiss could be reduced. I worked the EU contest over the weekend and had difficulty with weak stations. I could clearly see the CW on the pan adapter; but, could not copy the stations due to hiss.
I believe this is due to the previously reported audio aliasing issue. This caused a discernible hiss around 12-15 kHz. With a wide filter, the passband audio was probably strong enough to cover up most of the hiss. With a narrow filter the opposite was probably true. The aliasing issue is resolved in the next release so the hiss should be gone. If it's not, please let me know and I'll look more into it.0
Will check and report back after the next release is available.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
