High CPU usage since installing SmartSDR/CAT.
Andrew VK5CV
G'day, In my Core2 Duo, 2.1GHz, Win7 ultimate x86, 3g Ram, Hybrid HDD system PSDR ran at under 30%CPU load. This was in fact largely panadapter graphic activity. Since installing SmartSDR CPU runs 40% for SmartSDR and 50% for NT kernal and system. Flex 6500. Not a lot of CPU headroom for anything else. NT kernal and system is active at this level with no applications running. I have seen mentions of this on Google for years (even with Vista) but no solutions for me yet. Any pointers are welcome. All drivers are uptodate as far as I can determine. Andrew de VK5ZUC
Andrew, Two suggestions... one check to make sure you have a reasonable graphics card in your system and that SmartSDR detects and is using the GPU. If you go to the setting menu on SmartSDR, it will tell you whether GPU acceleration is being used. Second, use the display button on the left of SmartSDR and reduce the frame rate. The default is 30 fps and from memory, PowerSDR was 15. Try reducing the frame count and you should see the CPU usage go down. SmartSDR really benefits from a GPU - even inexpensive graphics cards now have high power GPUs. Stu K6TU0
Stu, This seems to be independant of SmartSDR running. The high CPU usage is present all the time even with no apps running. Unfortunately my graphics card is limited and not upgradable in a small form factor box. However it copes with reduced frame rates and a smaller window. It is running direct X 11 and full hardware acceleration. New video drivers that came with a Dell 27inch screen helped a lot too. I suspect the Realtek 1G ethernet device but am stuck with it for now. Again limited upgrade path. An older driver may be better. After paying for the 6500 I want to avoid shelling out for a new PC. Andrew0
Try shutting down the CAT program, it seems to have CPU usage issues over a short time, you only need the CAT program running if your running any Loggers or other programs that use the CAT interface Bret Mills WX7Y0
Thanks Bret, Closing CAT doesn't seem to help. Will try to stop it starting. Andrew0
Thanks Guys, Tried all sorts of things. Finally Process Explorer tracked it down to a long expired and unused trial sound card program driver that was 2 years old! Why it was cranky just now who knows. Fine after it was uninstalled. PS: In the shower this AM I realised that when I set up the sound card with CAT for digital modes I may have selected that device even if only for an instant. Andrew1
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
