I'm lost on using CAT for MMTTY PTT
N4AB
How do I set up the 6700 and a CAT virtual port to use a PTT command from MTTY software? I am totaly new to SmartSDR CAT. Finally got my Logic 8 logging program to read data from the 6700 but not doing good with the MMTTY PTT.
I do not believe that SmartSDR supports PTT via handshaking lines yet. I know that CW keying via COM port is not yet implemented. I am not familiar with the Logic8/MMTTY combination, but if your software can issue a TX command via CAT, then you should be able to assert PTT that way. 73, Ray, K9DUR1
Ray, I think you are right. The CAT software version installed with Version 0.12.17 does not match the SmartSDR users guide. I guess I'll wait for the next up grade release. Thanks for the responce. 73 AL N4AB0
Al, This capability will be included in SmartSDR CAT v1.1.3 which will be in the next release of SmartSDR for Windows Preview.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
