Jumping to a DX spot with DX4WIN & the 6500/SSDR 12.17.
k0eoo
k0eoo Member ✭✭✭
edited March 2017 in SmartSDR CAT
Interfacing DX4WIN to 6500 problem. I am able to connect DX4WIN to my 6500 OK as long as I have RXB turned on when I try and connect DX4WIN to the radio. But, the 6500 does a HARD crash if I try and snap to a spot in DX4WIN that is on a different band than the one the 6500 is currently on. What I would like to see is the slice and RXA and RXB would pop to the DX spot clicked on. Thanks, Dennis, k0eoo
  • BobT
    BobT Company Adviser
    edited August 2013
    Dennis, The way CAT works (and what I verified in testing with N1MM and DX Lab Suite) is that clicking on a split spot will move RX A to the DX frequency and RX B to the split frequency. If RX B doesn't exist, CAT will create it. I never tried that on a band I wasn't monitoring so that is an error on my part. Testing spots is difficult at best because they just aren't available most of the time so I have to emulate them. I'll take a look at it and see what I can discover. 73, BobT
  • Al - K0VM
    Al - K0VM Member
    edited August 2013
    Dennis, WIth the current version of SSDR, you need to select the new band ( using the left hand band selecctor ) before your click the spot.. (If the new band is not to far removed form the current band ( 20/17, 40/30) , just clickingthe spot MAY work. AL, K0VM
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2017
    Hello Bob and Al, Thank you for your comments. I already had verified that DX jumping on a spot does work if its in the same Band I'm arleady on. I just wanted to make sure Flex was aware that it doesn't work if the SSDR isn't showing the same band thats all.... I might mention the Flex5000A jumps to a different band just fine and I love it... Again, thanks!!
